RE: Phoenix 8 Help
Clint
I had sent you an email days ago. Did you not get it? As I said in the email, it is zero. If you were to put 1" blocks under each wing tip it makes it zero. It is to say the Leading and Trailing edges are straight. I used a six foot straight edge on the table , drew center lines on the trailing edge and line everything up when joining the the wing halves.
Don
Please note I made your fuselage with West Systems Epoxy Resin and Polyester Resin is not recommended for anything being attached to it. Use epoxy on epoxy only for best results. If you need any other help feel free to ask.
