RE: mcpx and 450 heli?
if your titan is jumping up or down when you hit the idle up swtich, you need to go into your radio and check the pitch curve settings. they should be the same in both modes for the last 3 settings on a 5 point set up, so you don't get what is happening to you. and no, you can't have 0 pitch or throttle at low stick if your in idle up. that's what normal mode is for
