RE: Nitro Planes CMP P28 Piper Arrow ARF
I have a question on the area where the servos for the Flaps go. I'm using a HS-645MG Standard Servo but I notice that it sits a bit to high and because of this I can't use the 2 mm plywood that goes over the top of the servo (it doesn't sit flush with the servo). I wanted to use the "single arm" on the servo but again it sits to high. Also the two pieces of plywood are really flimsy and might need to be changed. What mods. need to be done especially in the area of the flaps? Photos of this area would help. Thanks.
