RE: OS 33GT Gasoline Engine for Pattern
Ed, that makes good sense as the RCEXL unit requires no min RPM to fire. I'm sure Matt will let us know what the end fix is.
Matt. I'm quite interested in your DLE 55 setup. What header did you use and what was the length that worked the best? Pretty sure this is the setup I will go with.
