RE: Patterns from prints made easy
I use 3M-77 contact adhesive spray on the template and stick it to the wood. I also use the spray to stack multiple sheets of balsa for cutting the same part (wing ribs). Just make sure to only spray one side otherwise it becomes almost permanent and impossible to get the template off or seperate the parts.
