RCU Forums - View Single Post - Profile foamy
Old 12-19-2011 | 04:48 PM
flyboy138's Avatar
flyboy138
Default RE: Profile foamy
ORIGINAL: WaffleMan
ORIGINAL: flyboy138
Best Profile foamy out there bar none .I have owned one of these for 6 months.Next best thing to having a reset computer button and it will do all the tricks you can throw at it.
http://wmparkflyers.com/MX2.aspx
But how many times did you fly it in those 6 months? How many times did it crash? The lifespan of such a plane depends more on the pilot than the airframe.
Waffleman I try to fly it every chance I get I would say 4 to 5 times a week It likes calm winds so I like to fly before sunset I flew it tonight with a little bit of wind I have 4 batterys for it that gives me 7 minutes flight time for each battery.I have crash it a lot of times.It is put together with a glue called professional welder its an amazing glue works so well that that is what your control surfaces are hinged with.The worst crash's will crack the foam or if the crash is really bad you could split a hinge apart and all you do is run some glue down the hinge and take a credit card and wipe the excess away and you have your self a new hinge what I'm getting at is I have crash a ton of times and a little professional welder and you are flying again mine flys just as good as the day I bought. I'm telling you they are a blast to fly and 3D"s like no other.
