Sounds good that the Reeves canopy fits, as that is the one I have in the mail too
The other plastic broken bits are the bulges that are next to the long cannons on the LE of the wings.
Im going to repaint mine to an earlier Mk spitfire model, so I wont be installing the guns and bulges anyway
My oleo struts dont have much slop in them.
But the trunion block is quite a lot thinner than the red frames its installed into, so it can slide sideways quite a bit.
Installing washers between the frame and trunion might not be a good idea, as all the load will be transĀ“fered through the little area of the washer.
Will have to look into this later.
