RCU Forums - View Single Post - correct Antenna orientation
Old 12-27-2011 | 04:10 PM
  #38
opjose's Avatar
opjose
Default RE: correct Antenna orientation
Also remember that the range check function is for use out at your field, not in a residential area where you are VERY likely to get signal noise from WiFi and other devices.
Even though 2.4's are said to be immune to interference, that does not mean something else that is chatting on the same frequency range, cannot lower reception range due to noise being generated.
