RE: OPS 60 in Classic Pattern Saturn
Hello Ralph,
As I read your original post, I thought, " sounds like an overly short pipe." Your small prop experiment bears this out. Lengthen it 1/2 maybe 3/4 of an inch.
Also, your pipe pressure tap location in the header is less than optimal: you' would benefit from putting the tap at the high point of the pipe.
Regards,
Dean Pappas
