RCU Forums - View Single Post - Fabricating rigid and lightweight push rods
Old 12-29-2011 | 02:30 PM
aussiesteve's Avatar
aussiesteve
Default RE: Fabricating rigid and lightweight push rods
I have been using a similar system for all sizes of planes fom 0.60 size to 42%'ers for years but I get off the shelf ends from Central Hobbies.
[link]http://www.centralhobbies.com/control_linkage/pushrod3.htm[/link]
A couple of tips for you on the system you are using.
JB weld is definitely recommended over the 5 min epoxy - especially for larger planes
Use a solvent wash on the inside of the carbon tube before gluing, no matter what glue you use.
Make sure the Carbon tube you are using is a very close fit on the threaded rod you are using.
