ORIGINAL: bdyman
ok so i reversed the cables, and nothing from the wheel when used as throttle, but throttle works the steering, so im going to rebind the truck sunday night when i get back to my house since im at the fiances for the weekend glad i have my ken block car to play around with until then
thanks so much for your help
one more quick question could i use any reciever and controller in the volcano
yes, you can use any other radio/reciever you want.
If rebinding does not solve the problem, then fill out the warrenty form on redcats site....and in the message box state that you did the rebinding and the swapping of cables and found that the servo is good and the steering function on the radio does not work.
I had the same thing happen to one of my redcat 2.4 radios....but it was after my son threw the radio on the ground[&:]
