RE: Solo props, up front and personal
Hi Mike,
Hear is what you would get, the adaptor is basiclly a six bolt back plate that get's bolted to your engine, then there are some pin's in it that engage into the back of the prop hub itself, then there is a machined threaded stud that screws into that adapter to hold the prop hub on, it is also threaded on the other end to accept your spinner bolt. This is for my evolution 80 motor and the only thing you need to do is check the bolts after every ten flights or so cause they say not to use any thread locker on the bolts of the assembly. I would also think that you would'nt have any problems cause they are running these prop setup's on the big moki radials with out any problems at all.
