ORIGINAL: readyturn
I agree also, made them this way also, for the cf rods I bought a couple of cheap arrows and cut them to fit, held up well. used on a 1/4 scale Taylor craft.
ORIGINAL: karolh
In the past I have used metal rods with only one end threaded with CF rod, but what I did was to drill a hole just the size of the metal rod about 2'' from each end of the CF rod and then make a short 90 deg. bend at the end of the unthreaded portion of the metal rod to allow it to protrude from inside the CF rod and then fill in some 30 mins. epoxy into the CF rod to hold the metal rod in place. The 90 deg. bend in the metal rod acts as a permanent stop while the epoxy keeps it firmly in place.
Karol
I second this method... However, I use JB Weld instead of epoxy. [img][/img]
Rick
