RCU Forums - View Single Post - T&J Models  Gloster Meteor (short kit)(EDF Jet)
Old 01-03-2012 | 09:26 AM
TonyBuilder's Avatar
TonyBuilder
Default RE: T&J Models Gloster Meteor (short kit)(EDF Jet)
ORIGINAL: JeffH
I am thinking of building this plane as well. I would keep the 1/16th wing sheeting, but I might consider sheeting the fuse with 3/32'' since strip planking can lead to sanding if you arent spot on the money with the planks.
I agree on the planking and will consider 3/32 also, I like to sand so that should end up at 1/16+- after sanding.
TB
