ORIGINAL: grrmisfit
now on to my next small question
it seems there is no hole for the throttle tube right before the servos like there is for the rudder/wheel . should i drill one? when i move the arm with servo it raises up a bit
heres a picture
http://img18.imageshack.us/img18/6647/imag0515h.jpg
Yes, many planes do not come with a tube hole pre-drilled so that you can utilize different types of engines and setups.
Remember to avoid using an all metal pushrod setup from the engine to the servo as this can cause interference even with 2.4gHz.
I try to use plastic Sullivan Gold-N-Rod setups for the throttles when possible.
