ORIGINAL: stalledout
I ended up creating a flybar rod from a used bike spoke.
Cool!
I think I had previously adjusted the swashplate/servo to get rid of this left turning tendency. Any suggestions?
Thanks.
So, you're heli was going to the left, you adjusted it (from what you could tell), and it still goes left. Let's see:
1) Did you adjust the servos when then where on, and in the neural position? (unplug the main motor, so you don't turn it on by mistake).
2) How did you adjust the servo arms?
3) Double check that nothing else is broken. You may have a broken part that causing the heli to go to the left.
4) Double check the balance. Make sure it doesn't lean to the left.
-Dave
