ORIGINAL: djchip
i belive the do not turn freely and when i turn it on the spur gear does not turn at all . i will check better later on afterwork . and possbile put a video to show it better , unless we fix this
Ok, if the spur gear...and wheels dont turn freely then something is jammed or stuck.
make sure nothing got stuck between the spur and pinion gear....
then spin 1 tire...and see if the opposite tire turns(should turn opposite direction) do this to both the front and rear. this will check if the diffs are bad.
