RE: Lightest, most reliable ignition on the planet, Guaranteed!
AV8TOR, I am getting all excited about taking a SuperTiger 2300 and have Ken Lambert install needle bearings on the rod and a Walbro carb adapter. Then use the Gas/glow mix and a hot glow plug. It should be a good running engine without the hassle of ignition components and battery weight. If it did not pan out...I could install a RCEXL ignition and run strait gas with 32-1 oil. Capt,n
