RE: Flaps or Something Else?
Sounds like a split flaps. For me it’s better to use it using variable or with 3-position switch. This kind of flaps has more drag compare to other flaps, lesser lift but gives you an advantage at higher angle over the plain one. It delays the separation of airflow on the top at higher angle.
