RE: T&J Models Gloster Meteor (short kit)(EDF Jet)
<div style="margin: 0in 0in 10pt">I added a piece of 2mil carbon fiber to the fin to strengthen it up. Mostly because I’m afraid of breaking it off during transport.
<div style="margin: 0in 0in 10pt">I got the wing ends done and the ailerons. I am doing a closed scale hinge on the ailerons so I added some balsa to the LE and a hard point for my control horn. I like the design that Jim made for this kit but I want to use the Sullivan horn.<div style="margin: 0in 0in 10pt">Started the center section, the spars and the ribs. I double checked everything, marked it and still screwed up. Put the one with the LG hole on first. Just needed to cut a new hole. The landing gear mount is missing a tab so you need to cut one in.</div></div></div>
