RCU Forums - View Single Post - T&J Models  Gloster Meteor (short kit)(EDF Jet)
Old 01-26-2012 | 11:41 AM
TonyBuilder's Avatar
TonyBuilder
Default RE: T&J Models Gloster Meteor (short kit)(EDF Jet)
<div style="margin: 0in 0in 10pt">Wing</div><div style="margin: 0in 0in 10pt">So I got the wing pretty much together. I kind of do it my own way so it my look like I&rsquo;m out of sequence.</div><div style="margin: 0in 0in 10pt">First I framed up the center section with the front and back spars. Then I sheathed the bottom, cleaned it up and rough sanded it. Next I attached the outer wings, 30 min epoxy overnight. Then I sheathed the bottom, trimmed and sanded. The ailerons are all done and ready for the hinge point to be drilled.</div><div style="margin: 0in 0in 10pt">I did the servo cut out like this. First I glue in the LE sheathing, I&rsquo;m using 4&rdquo; and 6&rdquo; 1/6 balsa.</div><div style="margin: 0in 0in 10pt">I cut the center section of balsa to fit. I tape it in place then screw the servo hatch screws threw the inside of the balsa. I then turn the wing over and place the servo hatch over the holes and screw it down. Then I trace it out. I remove screws and the balsa sheet. Then I screw the hatch back onto the balsa ad cut around it with a fresh blade, sand and fit the hatch, easy as pie!</div>
ID:	1719363   Click image for larger version
ID:	1719364   Click image for larger version
ID:	1719365   Click image for larger version
ID:	1719366   Click image for larger version
ID:	1719367   Click image for larger version
ID:	1719368   Click image for larger version
ID:	1719369   Click image for larger version
ID:	1719371   Click image for larger version
ID:	1719372   Click image for larger version
ID:	1719373   Click image for larger version
