RCU Forums - View Single Post - T&J Models  Gloster Meteor (short kit)(EDF Jet)
Old 01-26-2012 | 12:13 PM
TonyBuilder's Avatar
TonyBuilder
Default RE: T&J Models Gloster Meteor (short kit)(EDF Jet)
<div style="margin: 0in 0in 10pt">The wing is very well designed and it is very strong. I found only one miss cut part. The landing gear mounts needs to be cut to fit R3. There is a slot in R3 but no tab on the mount so I just cut a tab into the mount and it fits great. The plans has one typo as it tells you to use 1/8x1/2 for the front and back spar, but the drawings show the correct 1/8x1/4 for the rear spar but it is noted as 1/8x1/2. Jim knows about this and may change it for any new plans going out, not a big deal. The material list is missing the 1/4x1/4 balsa and the balsa for the LE. All in all the plans are great and the wood cutting is very good.</div><div style="margin: 0in 0in 10pt"></div><div style="margin: 0in 0in 10pt">Next I will fit the fans and finish the wing.</div><div style="margin: 0in 0in 10pt"></div><div style="margin: 0in 0in 10pt">TB</div>
