RE: T&J Models Gloster Meteor (short kit)(EDF Jet)
<div style="margin: 0in 0in 10pt">Wing</div><div style="margin: 0in 0in 10pt"></div><div style="margin: 0in 0in 10pt">Well The wing is coming together nicely. I ran my servo leads in and routed them threw the rear spar. You need to cut a hole in the rib where the wire exists the spar. I also threaded all my wires for the motors in, no need to cut any holes.
<div style="margin: 0in 0in 10pt">I installed some blocks for the fan mounts, also I did some reinforcing of the retract mount. Retracts are all fitted for now. I will drill them out once the nacelle is planked. I am not sure what I will do with the gear, and I’m leaning to not do gear doors, too much to go wrong for a day to day flying model.</div>
TB</div>
