RCU Forums - View Single Post - T&J Models  Gloster Meteor (short kit)(EDF Jet)
Old 01-30-2012 | 08:30 AM
TonyBuilder's Avatar
TonyBuilder
Default RE: T&J Models Gloster Meteor (short kit)(EDF Jet)
<div style="margin: 0in 0in 10pt">Hinge pockets</div><div style="margin: 0in 0in 10pt"> I prepped and installed the hinge pocket on the wing doing my standard carbon fiber pocket. Just round off the aileron, I use a piece of 3/4" and 1" PVC that I ripped in half with some sticker sand paper. I start with 2 mill carbon fiber. Steps: 1. I take a piece of wax paper and put it between the wing and a piece of scrap balsa sheeting (1/16) then I clamp it to the wing. 2. I cut a piece of CF and lay it in up agents the TE of the aileron pocket. 3. I the clamp it down to the scrap balsa and glue it in with thin CA. 4. I use a 1/16x1/16 balsa strip and glue it in up agents the TE and on the CF. I don’t clamp this, just use a rod to hold it in place as you glue it in. that’s it, now you have a nice and tight hinge pocket. I sand it flush with the end of the wing then glue in the wing tip block.</div><div style="margin: 0in 0in 10pt"> </div>
ID:	1721065   Click image for larger version
ID:	1721066   Click image for larger version
ID:	1721067   Click image for larger version
ID:	1721068   Click image for larger version
ID:	1721069   Click image for larger version
ID:	1721070   Click image for larger version
ID:	1721071   Click image for larger version
ID:	1721073   Click image for larger version
ID:	1721074   Click image for larger version
ID:	1721075   Click image for larger version
