RE: Newbie to Electric Pattern
Mikey
I note you say you are going to buy "at least two chargers and three sets of batteries". Why? one charger is all you need to start with and you will get by on two battery packs. You will need a 12volt power supply to use your cellpro off the mains and a heavy duty battery for field charging, The cellpro will charge your 5S packs at 2C in 30 minutes and if you leave home with your two packs charged you can have 6 flights in a three hour period which I find is enough for me.
John
