RCU Forums - View Single Post - Help with E-Starter
Old 08-28-2003 | 07:40 PM
jmasterman
Default Help with E-Starter
2s2p sounds right with a 10X8 prop.
Use a new blade to cut the ailerons and tape the hinge gaps after you mount them This will improve their response. The plane turns best with a little rudder mixed in.
The landing gear is a weak spot. I used epoxy. I also recommend backing up the battery door with a velcro flap so you don't loas a battery pack. (Yours will cost more than the plane!)
