RE: Eflite 110 info
also change the Soft Start mode to Normal. Soft start is usually reserved for heli use, certainly not rrequired on 17" props. You should check with Axi for pwm rate, 8 might be fine, but its possible it could be 12 ion these bigger motors. flytreetimes
