RE: A6E Intruder Test Flight
Hi Mirce, I am planning on bringing this to TG. Andy the dry weight was just in at 55 lbs. I think if I did this again I could shave off around 4 pounds. Ian's comment about power and the issues surrounding it is exactly right. The thrust tube arrangement makes for reduced thrust efficiency. Kirkj, the molds will ultimately go to Mibo. George, yes it has slats. I had a problem with a servo on the left slat when we were at the field, so I locked the slats for the flight you saw in the video.
