RCU Forums - View Single Post - Pull-Pull cable tension
Old 03-06-2012 | 06:17 PM
spaceworm
Default RE: Pull-Pull cable tension
I might be seeing it all wrong, but your installation is not typical for a pull-pull setup. Their only needs to be one servo, and the distance between the holes in that servos arm needs to be the same as the distance between the arm on the rudder post. The servo should be on the same centerline as the rudder. Or, are just putting us on with the setup shown?
