RE: Pull-Pull cable tension
If you have your cables to tight it may create a bind at the hinge or pivoting surface. I don't get my cables very tight very barely vibrate if plucked. Can you loosen your cables just a bit and retest? IMHO it is most important to have equal bellcrank distance at both the control surface and servo, otherwise a bind or slop can develope.
