RCU Forums - View Single Post - Filler/Putty
Thread: Filler/Putty
Old 03-09-2012 | 03:10 PM
raptureboy's Avatar
raptureboy
Default RE: Filler/Putty
Bondo works in small quantities if you add the correct amount of catalyst. Also if you rough up the surface with 80 grit and then use epoxy with micro balloons followed by the spot putty that works well also.
