RE: Throttle Cutoff for electric with 9C
Krysta,
I have changed the throttle reverse per the instructions on page 31 of the manual per your suggestion. At this point the rate is set to zero and I get no impact when I switch on Throttle-cut. Do I need to change the rate or is there some other change that needs to be made?
Bob
