MXSR ailron problem question.
Hello all,
I'll try to explain the best i can...
On my MSXR , when i turn on the radio, then the receiver switch. Everything works fine exept the right servo ( ailron ) I have changed the Y extension, didn't change a thing, then i have changed the servo extension. same problem.
When I unconnect the y extension, then reconnect...everything works fine... turn off receiver switch, then radio... Then if i turn everything on again... right servo ( ailron ) won't operate !!!! there i am back to unplug the Y from servo extension, plug it back and then it works !!! if i turn off everything...next time i turn on, nothing works, i am back to same scenario again and again. ( i have changed the Y twice and the servo extension twice as well )
What is the problem ????
Thank u
