ORIGINAL: Scorpion Racing
Well, no pictures of the original item described! [
] I guess we should tweak the CAD file for maximum usability. I will try to work on it this week if I can. were you thinking of using a CNC lathe for these, and are there any tolerances that need to be adjusted for?
Actually, I was kinda thinking of using a laser to cut them. You are right in that we should probably add some tolerances to the dimensions. Perhaps if we undersized everything by 0.005" it would act like a "no-go" gauge and thereby be easier to use.
