RE: SORRY,BUT I HAVE TO ASK AGAIN: HANGAR 9 PIPER CUB ARF 80
I would recommend balancing the plane laterally whether you were adding the camera or not, but especially since you are adding a camera. If you need to add weight temporarily, just use some loose change and packing tape on the bottom of the wing tip. For permanent installation you can use lead 1/4 ounce weights, or whatever is needed, slit the covering, and tuck it up in the wingtip with epoxy. The further out on the tips you locate the weight then obviously the less you would need to add.
I have the great planes 40 with a 54 four stroke and it flies fine. It's scale power. I'm sure it will fly your plane, it may eat up a little runway with some more weight and depending on the grass, but I can't imagine it will make too much difference in the air for cruising along. If you want some power to spare, I would probably go up motor size or to a 50 something 2 stroke.
