RE: Today's gas no problem... NO way...
Hi, I found a trick that was in Model airplane news or Model aviation, Can't remember, but it works. Use a 5 gal can and get 4 gal of 89 or 93 Gasoline, whatever you use and put 1 gallon of WATER in with it. Shake it up a lot or if if you prefer put half these quantities in to make shaking easier. shake it a long time, this will attach the Ethanol to the water and separate from the Gas. Let it sit 8 hours minimum or just do the next step the next day. The water will sink to the bottom as will the Ethanol .After all this, pour slowly or better yet, siphon off 3.5 gal and leave the rest for waste. the resulting fuel will be free of Ethanol. I put a tap on the bottom of my shake can and pour from the bottom tap into a clear cup until there is no water as it sinks in the cup with fuel and is quite noticeable. Any Pilots will understand as you must remove water from the tanks in wings and such the same way. I remember reading a article about South American RC flying and what they have to do because there fuel is worse. hope this helps. Blake K
