RE: pushrod assembly
There is a lot of negitive talk about the Sullivan flex rods flexing. To a point it is true. If the outside rod isn't installed with bracing or there are several inches of it sticking out the back before it is attached to the control. It also gets soft in the heat. I have found it works very well in a lot of planes like Cubs and trainers where a bit of flex doesn't mater. It's easy to install and can be slightly bent to go around things. I keep a supply in my shop and use it in some builds.
