RE: Motor or ESC problem?
I recently purchased a Turnigy Trust 55A ESC from Hobby King along with a 2200mAh 3S battery as well. Installed them both in the E-Flight Leader 480 using an E Flight 480 motor. Followed all the directions, got good solder conntections from esc to Deans plug. Turned on Tx, plugged in CH 3 from ESC, plugged in Batt with Tx at low throttle. Should of heard either one or two beeps. Nada! I even switched motor leads, but that only changes direction of rotation. Still nothing. Re-tried...nada. So, I unplugged batt and set Tx to full (as if I was going into programming mode), still nothing. At this point, I think I got a bad ESC.....am I missing something?
Tim
