RE: JR 12X/Weatronic users!
Hello guys,
Once again, thank you for your feedback and I apologise for the late reply as I have been busy with other committments.
I have performed extensive testing and can without any doubt rule out the patch cable. Replacing the cable with a new item did not change anything.
What I did notice was that once the voltage reached/approached the 9.0v threshold, the "RF on" command would not work, and the weatronic module would NOT power up. Putting a very brief charge into the transmitter pack rectified this situation. I performed countless flights after a full charge without any problems what so ever.
If there are other users of this system out there that can support the tests I have performed I would very interested to hear from you.
Best Regards, Frank
