RCU Forums - View Single Post - .40-.52 Swift Racer
Old 04-20-2012, 05:55 PM
14Glen
Default RE: .40-.52 Swift Racer
Hello All,
Well I worked on the plane today.
1st. pix; is an over all.
2nd. is of glued in pins. (The hinges a 1 1/2 wide and each side is an inch deep. I also drilled 2 holes per side to get glue all the way in.)
3rd. is the rear wing glued in and pined in with 4 pins.
4th. & 5th. are glued in extra support.
6, 7 & 8th are with the wing set on.
I went over all the joints that i could get too with CA. Fire wall too.
My son was helping with part of it and put too much CA on one part and it ran on the ****kote. So is there any thing I can use to get the drip off with?
Thanks, Glen
ID:	1752865   Click image for larger version
ID:	1752866   Click image for larger version
ID:	1752867   Click image for larger version
ID:	1752868   Click image for larger version
ID:	1752869   Click image for larger version
ID:	1752870   Click image for larger version
ID:	1752871   Click image for larger version
