RCU Forums - View Single Post - Scratch Designed/Built Sailplane
Old 04-22-2012, 05:02 PM
  #54
Nodd
Nodd's Avatar
Default RE: Scratch Designed/Built Sailplane
Why is it the last 10% takes 90% of the time?
So I started adding gussets to the v-tail. I carefully measured the required angle then set about making 32 of these little buggers...
Then I noticed, duh, I'd need different shaped gussets for different areas of the tail. The leading edge, for example, runs at a different angle to the ribs than at trailing edge. After a long groan I tossed most of them & set about cutting out a new set. Anyway here's a panel with the corrected gussets installed. Came out nice & strong & fairly light...
And now for the next time sucking issue...
One of my ruddervators (love that word) annoyingly appears to have developed a moderate warp along its hinge line...
So back to my damp sponge trick, I saturated the wood then using a straight-edge as a guide, secured it to my workbench. I'll let it sit overnight, fingers crossed she'll be straightened out come morning...
