ORIGINAL: KW_Counter
A good ESC designed for LiPos will have a cutoff voltage above 3 volts per cell.
This is to protect the battery from damage due to excessive drain.
Good Luck,
KW_Counter
Definitely understand. However this setup is to power an Amplifier for a music system at the field. Take a look at the link in my initial note. I want to know if I can wire a 3S LiPo to power the Amplifier and not bring a generator. Goldenduff mentioned LVC and admittedly, I have never seen anything that would accomplish that (other than an ESC). Are you suggesting Ipurchase an ESC? Maybe Iget a 12v field battery and power it that way ...
Thanks.
