saito 125 or dle 20
ok guys, I have an pulse 125 that has os 91 fs thatI previously had weight and balance problems with. Solved with alot of weight but the os 91 just isn't enough power. Question isI have a saito 125a that is a little damaged from a previous crash, to the tune of 230.00 to fix it,I know this would be enough power but i've also considered putting a dle 20 on this plane also. If you put the dle 20 inwould you invert or just put it upright since i already have a cowl thats cut out for the os 91? let me know what you think saito 125 or dle20 , thanks alot for any suggestions adam
