RCU Forums - View Single Post - wiring of AMT CTF button
Old 05-04-2012 | 11:48 AM
Skycat66
Default RE: wiring of AMT CTF button
Here the wiring diagram of the switch.
Switch can be a (moment) toggle or push button type
If you want to go to single channel control please connect a JR lead to the futaba lead (white=orange, red=red, black=braun) and connect this to the switch input lead of the ECU.
Programming
1. Push CTF switch so it short circuit the white and black lead
2. Switch on the ECU. Beeps from high pitch to low pitch
3. Release CTF switch
4. Place transmitter OPS switch in emer. stop position. This can be a switch or trim input on your transmitter.
5. Push CTH so ECU will beep once
6. Place transmitter OPS switchin auto stop position
7.Push CTH so ECU will beep once
8. Place transmitter OPS switchin run position
9. Push CTH so ECU will beep once
10. Place Trottle in 0% (idle) position
11. Push CTH so ECU will beep once
12. Place throttle in 100% (max.) position
13. Push CTH so ECU will beep once
14. ECU will initialize and test if programming is correct.
Low, mid and high pitch beeps must be given by the ECU if OPS (operatings switch) is moved or throttle stick is moved.
<br type="_moz" />
