Now I can dive bomb the 3d hotshots...
Because of the added wieght, the plane flys like a brick. Italso has the tedancy to spin if rolle onto its side. you have to use a lot of rudder in the turns. landings are hot, and often end up in a nose over. (cracks in runway) However, since the modual is attached via velcro an a rubber band, all I have to do is open up the fuse and unplug the wire to remove it. I am considering a Eflie brushless motor for it because the smart people at spectrum gave a programming option for a seperate brushless esc and motor in the reciever itself. I would certainly help the power issues I have encountered with the bomb dropper.
