RCU Forums - View Single Post - Tamjets Gear Failsafe
Old 05-06-2012, 02:01 PM
jetnuno
Default RE: Tamjets Gear Failsafe
Hi Mark,
Yes it can, as long as you have both doors and gear installed in the same pneumatic circuit. Also be sure to have a large tank to avoid a drastic pressure drop in the event of a leak. That would leave the doors or gear half way.
If you use separate pressure tanks for gear and doors, both should be connected to the Tams device making both as only one circuit.
Also both gear and doors have to use ONLY 1 CHANNEL
Regards
Nuno
