RE: wiring of AMT CTF button
We could not get it to work in single ch mode, although the ecu beeped each time when pressing the CTF button for the different throttle positions, we could only get an alternating beep with nothing happening when we done the start sequence.
Thought initially it might have to do with the pulse width on the spektrum setup so tried 35mhz but no change.
We have now got it to work using 2ch mode and the three position switch. Would like if possible to use in single channel mode with the trim lever as we could do with the channels on the receiver.
Pegasus SN NL2313
