RE: CG Ultimate 10-300 Build
well, I should correct myself about the lazer cut part. I'm specifically refering to the fuselage sides, top, bottom and formers. In the newer version I would say they were CNC router cut rather than stamped out using a die. This made the tab fitment cumbersome since you had to square off all the rounded corners.
But i built two of these. The original kit that was available back n the 90's and the one from 2003 or 2004 just before Goldberg closed its doors. And I thought the die cut model went together better and was more percise when it came to the fuselage and notched LE and TE sticks.
just my opinion though
