RCU Forums - View Single Post - OS 91 FS w/ pump
Old 04-20-2002, 11:30 AM
henry1971
Default OS 91 FS w/ pump
Four strokes run fine inverted mounted, specially with a pump. you should not have any problems. you should have three ful lines going to your tank. An out , an in(fuel return) and a vent or overflow that gets routed out the bottom of your cowl. in the tank it should point to the top.
