RE: Info from Data Terminal after a shutdown
Attended a show yesterday and could not get the engine to start! Determined the fuel pump would not run. Tried to prime pump with the GSU and that would not work either. When I got home (after cursing quite a few times at a ruined day I had been waiting several months for) I connected the ECU lipo directly to the pump very briefly. Worked OK. After that I did two engine starts and was fine. Is the pump maybe not getting enough power during the start sequence?
Can someone also confirm if its OK to have the pump positioned horizontally? I've seen several other installs where this was the case. Ian (ModelbauUK) suggested it should be vertical. The filter is definitley mounted vertically. I did see guidance in the manual to suggest that.
Will be a while before I get to fly again but any advice on what can be done to prevent further start failures or engine shutdowns would be appreciated.
